6 members (walter74, JW51, 3B, J Lucas, Joe H, 1 invisible), 86 guests, and 3 robots.
Topics128,080
Posts1,055,952
Members48,430
#91192 04/25/2004 4:27 PM
Ok Guys, My fuel gage only works with the park/headlamps on. I've checked the circuit on the sender side, good ground & continuity up to the gauge. I've got battery voltage at the gauge.
Pink wire is batt., tan wire is the sender. With the test results I have gathered, the gauge should work. But, It only reads accurately when the lights are switched on. Now, I thought I was fairly knowledgeable when it came to electrical, I can fix 30k $ Caddy's all weak long. But, this one has got me baffled. Anyone have this problem before?? Thanks in advance.
Jim Sgrig
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
#91193 04/25/2004 4:35 PM
Sorry, it's a '66 Panel. Also, I can't find sender resistance values in the shop manual. Does anyone know what the resistance range is?
JS
#91194 04/25/2004 5:24 PM
Check the resistance between the tank and the frame. I'll bet you've got a bad ground in there somewhere. Try running a ground wire from the sending unit where it bolts into the tank, to a known good chassis ground. Also check the instrument panel ground to the dash. Anytime turning on another circuit alters the performance of something, there's a grounding problem somewhere.
#91195 04/25/2004 5:25 PM
Try adding an extra ground wire from one of the screws on back of inst panel to a good ground under the dash, just use a 12-18 ga wire & coupla terminals. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#91196 04/25/2004 5:53 PM
My suspicions are a bad ground. I've already cleaned the ground back at the tank to the sender.I ran a redundant ground to the cluster, no change. According to the schematic, the gauge & lights don't share any common grounds/ciruits.
Unless, the gauge is grounded to the cluster interally where it mounts?? I think I'll pull the cluster & check/clean the mounting points.
Thanks for the input guys.
JS
#91197 04/25/2004 6:08 PM
The gauge is a "balancing-coil" type, with one coil getting full voltage, and grounding to the dash. The other coil grounds through the sending unit. Both coils have to function properly for the gauge to read right. Check the gauge-to-dash panel circuit for a high-resistance connection.
#91198 04/25/2004 6:28 PM
Thanks Hotrod, that's where I was headed next. The one coil probably isn't grounded to cluster.
It got to be picking up the groung through the dash lamps when the lights are switched on.
Thanks again for your input.
JS
