9 members (John Dlugos, Buckeye998, Gray_Ghost, Gdads51, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53), 236 guests, and 0 robots.
Topics128,101
Posts1,056,172
Members48,436
#911626 01/14/2013 12:15 PM
Just installed a new fan blower switch in my '58...took out the toggle switch someone had installed some years back...
Problem is that the the switch shoould be OFF to the left and HIGH to the right...it's backwards and can't figure it out.
Please help...I'm sure it's a really stupid and easy fix but spent enough time and thought I would check with my favorite source....Stovebolt
Thanks a bunch for all the help
Steve in I-da-ho
Oh...it's the Deluxe Heater in case you were wondering..thanks
Shoot I forgot another issue...I only have two speeds....
OFF and HIGH
maybe you installed the switch upside down? 2 speeds only might mean it's mis-wired or the switch is defective
switch only goes in one way...one wire to the ignition switch and the other to the blower motor...very srange
The old fan switch was still in the assembly but with a broken connector and does the same thing as the new one. HIGH to the left and OFF to the right.
the way you got it isn't necessarily the way it came from the factory 50 years ago - have you looked at whether it can be flipped over? have you tried reversing the wire connections?
