| | | Forums66 Topics128,089 Posts1,056,352 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 1 Moderated | | Moderated Joined: Sep 2012 Posts: 1 | I have a 1959 Apache 38 1 ton. I want to replace the original front straight axle with a narrower straight axle with a disc brake set-up, should end up 60" backing plate to backing plate. Are there any recommendations for "donor" trucks that might accomplish this? I don't need the 1 ton front set up anymore as I've modified the read end to a non-dually (just using a wide single rear wheel).
| | | | | Joined: May 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2012 Posts: 51 | I am doing the same thing on my '46 1.5 ton. I found a front axle off of a '42 3/4 ton. This will give me an 8 lug wheel pattern and a wide variety of wheel choices. I am going to use a Chevy 14 bolt full floating axle on the rear, same 8 lug bolt pattern. What did you use for your rear axle, I haven't bought one yet. | | |
