| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91125 06/22/2003 3:22 AM | Joined: Jun 2003 Posts: 9 Member | | Member Joined: Jun 2003 Posts: 9 | Both to this forum and to the wonderful world of trucks with out of print repair manuals, impossible to find parts and devious electrical goblins...
However, tomorrow I am going to go do some work on a 65 GMC P/U, a 305 V6 3/4 ton (I think) with the idea of getting it road worthy enough to drive home.
The only problem that is a known quantity is the turn signal switch...which, of course, I couldn't find a replacement for anywhere. At least, not one that I was sure fit on this truck.
So, for now, my only question is what is the best way to go about solving this problem? Will the switch from later model GMC's or Chev's work?
If not, what is the easiest/best work around? Are there aftermarket switches that will work? Has anyone used a switch to bypass the one in the steering column and if so, exactly what kind of switch?
I tried to use the search function to get a few answers but that was....ummmm......tedious.
Any help or advice would be greatly appreciated....
\m/
#91126 06/23/2003 4:43 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I'm not sure what kind of wiring harness is on your present 65 column, but if it was me, I'd consider dropping a new tilt steering column in from your local scrap yard - most any GM column would do - the question would be whether or not the column harness would plug in. If not, then I would match the appropriate wires up (parks, turns, etc.) and connect them individually.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#91127 07/01/2003 12:15 AM | Joined: Apr 2003 Posts: 37 Member | | Member Joined: Apr 2003 Posts: 37 | Have you tried finding the switch at Chevy Duty? Chevy Duty Truck Parts
BiggerHammer "The key is in knowing where to hit it" | | |
