3 members (Hotrod Lincoln, BC59, 1 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | I pulled the valve cover and found the cap on the first valve (front of motor) has two good size pieces chipped off, I found the pieces laying among the valves. I'm wondering if I can easily replace that one cap or if the whole valve train has to be rebuilt. The motor is the stock 216 and near as I can tell its never had any major work done to it. It seemed to run ok last summer I just pulled the valve cover to paint it. Thanks in advance. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ct artdeco, could you provide us with a picture please? Valve spring retainers very seldom break apart without some physical damage. Replacing a retainer is a fairly simple job if you have a tool which will allow you to put compressed air into the cylinder through the spark plug hole, that should hold the valve on its seat while you re and re the retainer, hope that helps. | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | I added a photo to my flickr pics. Will the fitting from my compression tester work for putting air to the cylinder? Do I have to keep the air compressor running while I change the cap because the air would blow past the piston? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You could do it that way, another easier way is to put a small rope into the cylinder and then slowly turn the engine over so the rope pushes up on the valve heads. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That is only an oil deflector that is broken. They do not retain the spring, only oil control. You can change them by backing off the adjuster and they will lift right off. They were only used from 1941-47
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | The adjuster at the pushrods? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ct artdeco, yes as Pre '68 Dave said you can back off the pushrod adjusting screw and lift off the broken piece, they aren't absolutely necessary, but if you find another good one you could install it at the same time, hope that helps. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Loosen the jamb nut above the push rod and screw the screw out. You can then remove the oil deflector. If you can't find one, you don't really need the deflector at all. Just throw it away and adjust your valve to the proper lash. | | |
