4 members (Otto Skorzeny, dt235sd, delwrench, 1 invisible), 148 guests, and 2 robots.
Topics128,077
Posts1,056,280
Members48,441
#911073 01/12/2013 3:22 PM
Moderated
Moderated
I have a 1959 Apache 38 1 ton. I want to replace the original front straight axle with a narrower straight axle with a disc brake set-up, should end up 60" backing plate to backing plate. Are there any recommendations for "donor" trucks that might accomplish this? I don't need the 1 ton front set up anymore as I've modified the read end to a non-dually (just using a wide single rear wheel).
I am doing the same thing on my '46 1.5 ton. I found a front axle off of a '42 3/4 ton. This will give me an 8 lug wheel pattern and a wide variety of wheel choices. I am going to use a Chevy 14 bolt full floating axle on the rear, same 8 lug bolt pattern. What did you use for your rear axle, I haven't bought one yet.
1939 Chevy 1/2-Ton Pickup Truck
More pix on Photobucket
1946 1.5-Ton Chevrolet Stake Bed
1940 Chevy Sedan - Frame-off Restoration
