5 members (Stovebolt48, Rmillerfly, Shaffer's1950, 2 invisible), 93 guests, and 1 robot.
Topics128,050
Posts1,055,758
#91086 04/27/2004 1:20 PM
Junior Member
Junior Member
When having the body work done on my 66 chevy the gas gauge wire got pulled out does anybody know where it attaches behind the dash it has a crimp mark in the wire so it was pulled out of the connector
Thanks Dave
#91087 04/27/2004 2:07 PM
At the risk of stating the obvious, why don't you take the screws out of the gauge cluster, pull it free of the dash (while leaving it connected to the wiring harness), and look for an empty connector? If my memory is correct, those '60s clusters are surface-mount, not rear-mount like the '40s and '50s models. It shouldn't be too hard to pull it out enough to see the connections.
At the risk of stating the INCREDIBLY obvious, disconnect the battery first! grin
1954 GMC De Luxe COE
#91088 04/28/2004 1:07 PM
Junior Member
Junior Member
Obviously
