| | | Forums66 Topics128,179 Posts1,057,157 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | I need to replace the speaker in my Chevy Truck Radio (6 Volt) model 985792 (same as 986146). It is 5' Diameter . The only numbers on the speaker are 45505 (on Coil cover) and 1216013 on the speaker frame. I need to know what OHM speaker I need to use and if anyone has suggestions as to where I can buy a new speaker. Thanks for your help. Harold
Harold Is a restoration ever finished? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think you would be fine with a new 8 ohm speaker. The new speakers are of the permanent magnet type so you don't need to connect the 6 volt power supply to the speaker. You can probably find an appropriate speaker at this place. Antique Electronic Supply | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Thanks for your post. Harold
Harold Is a restoration ever finished? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I've had very good luck with this outfit. It's small and you will talk with the owner when you call. Tell him what your application is and I'm sure he will have a speaker that will work for you. http://www.turnswitch.com/services.htmDenny Graham Sandwich, IL
Denny G Sandwich, IL
