1 members (Russ_B_10), 91 guests, and 2 robots.
Topics128,050
Posts1,055,643
#910144 01/09/2013 4:16 PM
what the advantage or disadvantages of swapping 292 head to 250 eng.chevy of course.my 292 exhaust has much larger pipe than a 250.
johnhull #910211 01/09/2013 8:18 PM
All the heads are interchangeable 194/230/250/292. The integral head is not considered. The combustion chamber CCs change a bit, there is a list on inliners.org The exception is the 194 head. The combustion chamber in the 194 is IIRC 62-64 it will bump your compression a bit. I've also read there is no other advantages.I have a collection of heads if your interested in looking at them send me a PM.
Larry
I don't own a vehicle that isn't old enough to drink.
johnhull #910299 01/10/2013 9:18 AM
No real advantage, just swap the exhaust manifold.
Joe
johnhull #910389 01/10/2013 3:04 PM
Riding in the Passing Lane
The 292 heads have more rugged valves & have hardend seats. The exhaust valves are sodium filled & have rotaters on them. Through the years they have been switched around so one might have the lighter duty valves. The large opening straight down ex. manifold was used on the 1 1/2 ton & larger trucks. The 1 ton & smaller ex. manifold was near the same as the smaller engines.
1972 Chevy c10 Cheyenne Super
