3 members (TooMany2count, Rich'sToys, 1 invisible), 74 guests, and 7 robots.
Topics128,021
Posts1,055,353
Members48,420
#91027 11/27/2002 5:29 PM
where exactly does this go"flasher":
there are 7 wires
4 are markers
the other are
#91028 11/27/2002 5:36 PM
is this correct
1 flasher to bulb
2 flasher to power input
3 stop signal
#91029 11/27/2002 5:41 PM
Hey Reddspeed,
Here's a link to an Adobe Acrobat PDF file showing how mine is wired:
Turn Signal / Brake Circuit Wiring Diagram
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#91030 11/27/2002 6:49 PM
thanks alot man
that really helps
#91031 11/29/2002 7:59 AM
I don't know if this helps, but I took a different route. My stock turn signals weren't wired for 4-way flashers, and I decided not to chop into the wires to make it that way. The signals have no power when the ignition is off, which makes them useless for breakdowns, etc. What I did instead was tap into the cigarette lighter hot lead (straight off the battery), installed a switch, fuse, and flasher under the dash, and spliced into the brake wire after the brakelight switch. Sure the front lights don't flash, but I can shut off the truck and the rear lights flash brightly.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
