| | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91026 03/06/2002 1:38 AM | Joined: Nov 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 46 | I picked up a magnetic pickup style tach - such a deal!!! Now my problem is that it's calibrated for 4 or 8 cylinders and I have a V6 305. There is a calibration sticker on it, and using the ratios listed, I think it will display correctly if I get the pickup end of things correct. On the sticker it says for 8 cylinders and mag pickup "180T", which I interepted as putting two pickups 180 degrees apart? Under 4 cylinders it says "90T", so I'm thinking that for a 6 cylinder could I put 3 pickups 120 degrees apart??? Can I get the magnetic pickup at NAPA??? Should I just chuck this sucker in the dumpster and start over?? Thanks in advance Scott :confused: | | |
