| | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | what the advantage or disadvantages of swapping 292 head to 250 eng.chevy of course.my 292 exhaust has much larger pipe than a 250. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | All the heads are interchangeable 194/230/250/292. The integral head is not considered. The combustion chamber CCs change a bit, there is a list on inliners.org The exception is the 194 head. The combustion chamber in the 194 is IIRC 62-64 it will bump your compression a bit. I've also read there is no other advantages.I have a collection of heads if your interested in looking at them send me a PM.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | No real advantage, just swap the exhaust manifold.
Joe | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 292 heads have more rugged valves & have hardend seats. The exhaust valves are sodium filled & have rotaters on them. Through the years they have been switched around so one might have the lighter duty valves. The large opening straight down ex. manifold was used on the 1 1/2 ton & larger trucks. The 1 ton & smaller ex. manifold was near the same as the smaller engines. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
