| | | Forums66 Topics128,147 Posts1,056,801 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 65 | Just replaced all channels and rubbers in the door glass. Had to replace the drivers glass and it doesn't work well without me "helping" it go down. About 1/2 way down the glass gets out of level and binds. The passenger side works well, original glass but all new guts. Thanks for any input. | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I had the same problem when I replaced the channels and rubbers in my '53. I sprayed some spray silicone in the channels and it worked great. | | | | | Joined: Jan 2011 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 65 | Sounds like an easy fix, thanks twotone. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | As noted silicone spray can help (make sure there's no painting going on anywhere close) but it's possible you have the adjustment of the channels too loose as well.
| | | | | Joined: Jan 2011 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 65 | Not sure what you mean by "adjustment of the channels". Could you clarify? Thanks | | |
