Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (greenie-reddy, Otto Skorzeny, DennisM, IHPWR, GMCJammer51, Hotrod Lincoln, 1 invisible), 562 guests, and 1 robot.
Topics126,781
Posts1,039,297
Members48,100
Most Online2,175
Jul 21st, 2025
I have a 1954 3600 done with paint and wiring and about to road test. I polarized the regulator as per manual says, and it did not charge. With the motor running I did it again and it charged. When I turned the motor off and restarted it it would not charge until I polarized the regulator again with the motor running. This happened many times. I am using the generator I rebuilt and the regulator that came with the truck. It has been replaced before I got the truck. Do you think the regulator is at fault, because it does charge but on the high side at 15.6 volts. It just wont repolarize itself every time.
Thanks I'm really anxious to start driving my truck.
Tony
polarizing only needs to be done one time at most on an installation - I'd think sticking points in the reg - try giving it a rap with something next time instead of polarizing it - could also pop the cover and watch what's going on .... if it's overcharging you'll want to adjust it
I'll do that this morning, Thanks
Tony
Tony -
Some good info in this thread ...
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=732659#Post732659
Read all posts in the thread by "Hotrod Lincoln" and by "Kennethw". (4 pages)
- Lonnie
My '54 3104
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.132s Queries: 14 (0.059s) Memory: 0.6068 MB (Peak: 0.6445 MB) Data Comp: Zlib Server Time: 2025-09-22 20:57:00 UTC
Valid HTML 5 and Valid CSS
