1 members (1 invisible),
46
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Hi all. I stopped by the tire shop to get some used tires for my 48 driver and the owner gave me what I believe is a 292. He said it came out of a early 60's truck, but was a transplant as it had homemade mounts.
Where are the id numbers for a 292? This engine is pretty greasy, but I am guessing 292 because of the offset motor mounts. It does have a similar looking intake and exhaust to my 235's and 216's. The engine is complete except for the carb and starter. No idea what condition it is in, but the price is right. Wahoooo!!!!!
I gave a neighbor one of my spare doors for his 49 and in turn he gave me a 250 that was running and complete. I have yet to pick it up, because it is stored in his barn and I dont have room for it in mine. Are the motor mounts offset on the 250's? Thanks in advance for your help. | | |
#9095 09/15/2004 11:20 PM | Joined: Feb 2004 Posts: 29,763 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,763 | The 292 is the only stovebolt 6 I'm aware of with offset motor mounts. It should also have a bellhousing bolt pattern the same as a smallblock V-8. The harmonic balancer will be heavier than the other 6-cylinders of similar vintage, plus it's a little longer. Good engine, and the price was right, too! Jerry
| | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Thanks Guys, I am going to go pick it up tomorrow when I can get my father-in-laws loader. Do you think a 5 yard Volvo will lift it  I will run it by the car wash and knock off some of the crud and see just what I have. It was running when pulled (Ive heard that before) but I expect to do an overhaul at some point. It will probably just sit around for a while until I can get a couple of my truck projects going. Ralph | | |
