2 members (Gray_Ghost, RLB), 194 guests, and 0 robots.
Topics128,080
Posts1,056,060
Members48,433
#909513 01/07/2013 4:05 PM
Thought I'd share some pictures of one, I intend to put it in my 52 1 ton behind a Spicer 5 speed OD and a 3-53T detroit diesel.
Ratios on the 6041 are 2.14, 1.24, 1.00, and 0.86:1 for 1st through 4th gears respectively.
My 3053 spicer 5 speed has a 0.85:1 OD already, making double overdrive an effective 0.73:1.
It is a little on the large side for a 1 ton but it's not that big of a stretch. I like that it has a parking brake, I might use a disc brake conversion on the 14 bolt rear and that solves the parking problem without the expensive Cadillac calipers.
Pictures
https://picasaweb.google.com/118082002072608219229/DetroitDiesel353TSilver#5830826020581918802
https://picasaweb.google.com/118082002072608219229/DetroitDiesel353TSilver#5830826078757896274
https://picasaweb.google.com/118082002072608219229/DetroitDiesel353TSilver#5830826031919820658
Came out of this truck, what year is it?
https://picasaweb.google.com/118082002072608219229/DetroitDiesel353TSilver#5830825969193900642
https://picasaweb.google.com/118082002072608219229/DetroitDiesel353TSilver#5830826021559222866
And the whole album
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg,
The aux trans came out of a 1965 truck.
M = Conventional Tandem with Gas Engine.
8 = 2-1/2 Ton 80 Series (H.D.).
8 = 157" wheelbase.
3 = Cab (body type)
5 = 1965
P = Pontiac Assy. Plant
104983 = unit number starting with 100001.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
That old 80 series probably came with a 348 or a 409. Both of which are hard to find. Looks like it had a power tower with a winch at one time. Auxiliary shifters are getting hard to find too.
Thanks Mike.
I was wondering if it had a 409, that was my uneducated guess, the engine is long gone.
No power tower, the chain seen beside the transmission was from a jack shaft driven by a PTO on the main transmission.
Looked through my Spicer manuals last night and found I have both the service and parts manuals for the 6041, if I knew that before I had forgotten about them.
Grigg
---All pictures---
Grigg , youre so lucky to be able to find stuff like that all our old deralicts and scrap yards have about disapeared over here ..
live or die do it with spanner in hand
