9 members (KEVINSKI, Phak1, Rusty Rod, GMCJammer51, Rusty Heaps, 68ironhead, carbking, Jeff Ogden, 1 invisible), 378 guests, and 4 robots.
Topics128,162
Posts1,057,042
Members48,463
can anyone point me to anyone who knows about
modifying splash fed bigend 235ci engines to pressure fed
Although, the 216s and older 235s are often referred-to as being "splash oilers", real splash-oil lubrication is an even more primative oil system than the low-pressure rod-bearing dipper and directed-open-spray lubrication system. What is a "bigend 235"?
Here is a description of a conversion technique.
I apologize - that technique is for full-flow oil filtration (mistakenly termed full-pressure) . Maybe someone will post a link to an insert rod bearing and pressure feed/lubrication conversion?
I sent you a PM
Here's how a well-heeled hot rodder did it in the golden age:
From Wayne catalog(circa 1954).
I see from the Inliner's page that Beck's machine shop still does the conversion.
Hoyt
