5 members (Steveoreno, Phak1, kades51, NorCal52Suburban, TUTS 59), 87 guests, and 6 robots.
Topics128,187
Posts1,057,211
Members48,465
Does anyone know why the neoprene rear main seal ive seen for the 235 would not work on my 216. Of coarse i ran across this after i replaced my rope seal but i dont have my pan on yet! thanks Dirk
dbum
3B Offline
Hy dbum, on engines with shim adjusted main bearings the crankshaft may end up not exactly centered in the rear main bearing bore, this will load the seal unevenly and could cause a leak, and it will shorten the life of the "neoprene" seal, hope that helps.
