0 members (),
162
Mod | | | Forums66 Topics128,089 Posts1,056,441 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90923 11/09/2004 5:08 AM | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | My 79 Chevy C30 has a new battery, new battery cables, new alternator, new belt, and the battery won't hold a charge. In the wiring diagram I noticed a green wire from the alt directly to the battery. Is this wire responsible for charging the battery, or is it the red or black wire that runs from the connector on the alt? I thought that the red wire went to the ignition switch and the black wire went to the charge indicator. If it is the green wire that's bad, can I run a wire directly to the positive terminal of the battery? I really can't see where the existing green wire goes to.
69 C10 LWB 250 L-6/3spd 79 C30 Crew Cab Dually 454 V-8/TH-400
"Takes more than a coat of paint to make it at Thunder Road!"
#90924 11/09/2004 7:30 AM | Joined: Feb 2001 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 80 | http://www.off-road.com/chevy/tech/grill/diagram.jpg You might want to check out this wiring diagram. It shows a diesel engine, but my 76 Chevy has the same wiring with a heavy gauge dark green wire going to the horn, and a smaller gauge to the A/C pressure switch. There is no green wire coming off the alternator, just two reds and a brown. | | |
#90925 11/09/2004 7:30 PM | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | First of all, is the alternater charging 14 volts? Also you might have something draining the battery. If you have a volt meter, take the ground wire off the battery, take one lead from the meter and hook it to the battery and the other to the cable. ( you might have to switch wires on the meter) If it reads 12 volt, there is somthing draining the battery. With the meter hooked up, take the power wire off the alternater, if it goes to zero, you have a bad alternater. If you take the wire off the alternater and it is still 12 volts, start taking fuses out one at a time to find what is drawing power.normally the alternater will draw around five vols, thats fine | | |
#90926 11/09/2004 10:07 PM | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | Disconnect one of the battery cables, and see if you get a spark when you touch the cable back to the battery post. If so, there's a constant drain that's responsible for the battery failing. If not, the alternator might not be charging. Check the voltage at the battery with the engine stopped. It should be about 12.5 volts with a well-charged battery. Running voltage at the battery, also with a full-charged battery, should be between 13.5 and 14.5 volts. When the alternator is recharging a low battery, the voltage might drop as low as 13, but the charging current will be high, 60 amps or more. As the battery recharges, the amp rate will drop, and the voltage will increase. A good-condition, well-charged battery should drop the amp rate to 10 or less, and the voltage should go well above 14 volts. Do you have an internally-regulated alternator, or is there a voltage regulator somewhere in the circuit? The wiring will be very different, depending on what type of alternator you've got. Jerry
#90927 11/12/2004 3:56 PM | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | OK, I'm ready to lose it! I hate electrical problems!
While driving, my dash gauge is reading <8. The alternator is an internally regulated unit. While doing voltmeter testing, should I have the engine running or not? I'm lost. Thanx for the replies received so far. Dano
P.S. When trying to fix electrical problems, is it normal to have feelings of wanting to yank out the wiring harness and do a tribal yell at the top of my lungs.
#90928 11/12/2004 11:39 PM | Joined: Jul 2003 Posts: 85 Member | | Member Joined: Jul 2003 Posts: 85 | yes  | | |
#90929 11/12/2004 11:58 PM | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | Patience, We will get this figuered out. When you turn the key to the on position(not running) the volt gauge should read around 12 volts. When the engine is runing, the volt gauge should read 13 to 14 volts.that means it is charging. If the volts on the gauge is 12 volts or less, it's not charging. Ask the parts store where you bought it if the are able to bench test the alternater for you. It might be just a bad alternater right out of the box. | | |
#90930 11/13/2004 12:16 AM | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | The other thing you might want to check is make sure the big wire on the alternater has power. does not matter if the key is on or off. If it does not have power, follow the wire back and you should find the problem. By looking at the wireing diagram, it shows it going to a fuse link. They are the small wires that are conected to the main battery wire on the starter. Make sure they are all conected. If you find one burnt in half, that is your problem. To fix it right, you need to get fuse link wire. Fuse link saves your truck from a major melt down. | | |
#90931 11/13/2004 10:49 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Follow bigt,s test & than check the 2 small wires. One should be hot all the time. The other comes on with the ign. switch through a resistor wire (test light dim).  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#90932 11/25/2004 10:18 PM | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | After weeks of frustration; found out the "brand new" alternator was maybe bad "out of the box". I also found a bad section of wire in the harness. I don't know if the bad wire ruined the alt or not. Ran voltage tests and everything is OK fine!
Thanx to everyone and their advice. Dano
