1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 59 | I want to adjust the valves with the engine being cold first before I start it up and then I'll do it again when it is hot. The problem I'm having is figuring out when each piston is top dead center. I'm working on it solo so if there is an easy way of knowing when the piston is top dead center that would be great. Thanks, Bert | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Watch the valves when you rotate the crank. When neither move you have both valves close.
You should already have the plugs out, put a piece of thick wire into the spark plug hole and watch it.... you'll see the piston hit TDC (the wire will not move up anymore). | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | go to tech tips there are a couple of versions there. it is really simple put the ball on the pointer set the 6 specified valves, turn the engine 180 degrees and set the next 6 and that is all there is to it. I don't know exactly which ones at which point, that is why there is a tech tip. OOPS I mean 360 degrees, one full engine revolution, one half cam revolution.
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Turn the flywheel to TDC. Once there see if you can giggle the pushrods on #1 cylinder. If they are not loose, turn flywheel one full rotation and try again.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My experience has been that when set cold and checked after the engine temp has normalized there is little difference. I know the engineers stressed that the engine MUST be hot when setting valve lash and probably had good reason for that but my experience has been the opposite. I would certainly recommend that one recheck when hot after setting cold but don't be surprised if no re-adjustment is required.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I have always set valves .002 looser when cold and then found them to be real close when hot. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The graphs that are in the various shop manuals on this show a variation of the clearance while it is warming up. However, if you look at the cold value and the normalized engine temperature value, they are identical. I agree with Tiny. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That's a dangerous precedent to set. Folks will start talking bad about you.
