1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | anybody ever tried a cummins 6bta into a big bolt say a 6400 ,4speed manual ,, something i,m thinking of doing .
live or die do it with spanner in hand
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Grigg Mullens may have some good input to this topic. Hopefully he will see it and comment, even though he is doing a Detroit 4-53.
I know about 3 years ago a guy was posting on the oldgmctrucks website forum his progress in putting a 6-cylinder Cummins from a Dodge in a 3800 Chevy pickup.
You can search youtube and probably find someone whose done it.
Professional Novice
| | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | You could also check on 4btswaps.com Lots of cool conversions and grat info on the topic over there. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | At least up to 1954 the 6BT will be a very right fit, requires cab work to fit the length. | | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | You could also check on 4btswaps.com Lots of cool conversions and grat info on the topic over there. i tried to register on 4btswaps but it wouldnt recognise my email address so after the ,fitfh, attempt i gave up .. i,m still looking at other engine options but i,m limited to whats available in the uk..
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Send me a PM with your info and I'll see if I or one of the other moderators can get you registered over on 4btswaps. Grigg | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I can probably offer some pointers in the 4BT and 6BT realm as well. I agree, a 6BT will be tight, however a 4BTAA with a tweaked fuel pump will put out 220hp all day long. more if you start with the 4.5 liter.
make sure you use the larger marine damper, the 4B shakes like a dog passing a peach pit at idle.
| | | | | Joined: Jul 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 23 | Just finishing putting in a 4BT into my 1965 GMC K-10 added a 5 speed. Had almost 8" left over using the stock radiator location. Drove nice, 900lbs over the front axle. 6BT will be more, sat nicely between the frame rails. Rear quarter panels are just being painted. Grigg sent me over to 4btswaps when I asked about putting one in here. Great site. One guy has a 1963 crewcab with one installed. Jeff | | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | thanks for youre input upto now, not many 4bt engines in the uk ,and 6bt,s are getting a bit thin allthough thers still a few about ,most have gone for export to africa along wih perkins and bedford diesels bedford 330 was going to be my first option but they are almost impossable to buy theses days ,,
