7 members (jmoore, kades51, Otto Skorzeny, TexasA&M48Truck, Frank50, Jon G, 1 invisible), 74 guests, and 1 robot.
Topics128,132
Posts1,056,379
Members48,441
#90889 02/28/2004 12:36 AM
I finally got around to installing the runtz regulator on my gas gauge and hooking it back up. It works fine and is pretty accurate, but it bounces up and down every time I hit a bump. I don't think the sending unit has dead spots, I think the response of the gauge is too fast. Is there a way to dampen it? Should I add a capacitor between the sending unit and ground, or should there be some dampening built into the gauge?
The gauge and tank are stock 1950 units and I have a new wiring harness. It did the same thing on 6 volts.
Paint & Body Shop moderator
#90890 02/28/2004 2:24 AM
I have the same problem. It is accurate, but bounces or flickers.
#90891 02/28/2004 2:39 AM
My buddy's 1999 GMC & my bro's 2001 Silverado-both of the gas guages bounce around all the time. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#90892 02/28/2004 4:20 AM
Could it be a poor ground connection?
Mine does the same in my '46.
Union, Justice and Confidence
#90893 02/28/2004 12:38 PM
The fuel gauges in my 37 and 45 work ok but have nervous flickering needles.The gauge in my wifes 51 is just a little jumpy.There supposed to act that way,gives em character.
#90894 03/02/2004 7:51 PM
Mine used to get to a certain level and then bounce up or down. I fooled around with it and wound up opening the little metal box around the sender's resistor. It was full of loose rust and there was a break in the resistor wire. I bought a new one and it works fine. However, the place I bought from would not be recommended, since I had to redrill the mounting holes because they were off. - Scott
55 1st Chev.
#90895 03/02/2004 11:43 PM
Anonymous
Unregistered
Anonymous
Unregistered
4 spd - I would try an electrolytic cap with a resistor in series to limit inrush current on power up.
