| | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | Good morning friends... I came across some 6 lug 16" Chevy factory wheels that fit a 2k Sliverado. Being they are steel wheels, factory and chromed, I was thinking about trying them on my 64. I have a set of stock 70's rally wheels on it now but was thinking these would look better. I could get some tires the match the stock height etc.. I am not sure about the width etc.. I know that may be an issue... What do you guys thing..maybe you have tried it before?
At any rate I have not been out here in a while and wanted to say hey... i hope you all are doing good.. God bless, Michael
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Aug 2011 Posts: 4 New Guy | | New Guy Joined: Aug 2011 Posts: 4 | Hi Michael, I had a flat on my 66 one time and tried to use the steel spare from the 94 suburban that I had had at the time and the offset was way off. I imagine you may run into the same problem. Hope that helps.
Ian
ergbert 66 c10 fleetside 64 c30
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Good morning friends... I came across some 6 lug 16" Chevy factory wheels that fit a 2k Sliverado. Being they are steel wheels, factory and chromed, I was thinking about trying them on my 64. I have a set of stock 70's rally wheels on it now but was thinking these would look better. I could get some tires the match the stock height etc.. I am not sure about the width etc.. I know that may be an issue... What do you guys thing..maybe you have tried it before?
At any rate I have not been out here in a while and wanted to say hey... i hope you all are doing good.. God bless, Michael Michael, Good to see another SC fella on here! Hello from Columbia! Measure the backspacing on the wheels you have on the truck now. If the 16" wheels have similar backspacing you should be alright. I think the backspacing on the factory steel wheels on the 1964 trucks were around 3.5 or maybe 3.75". With 16" wheels, you can probably do OK with backspacing of 3.75" if you are running drum brakes. Make sure you test fit the new wheel on the front before you hand over the cash. Here's a helpful website to learn what all the terms mean if you aren't familiar with them. Rims N Tires | | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | Hey Lugnutz, awesome website. 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The wheels from the '99 and up Silverado will not work, the backspace is too deep.
Bill Burmeister | | |
