| | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 49 | My 1954 3100 project starter housing is broken. The previous owner had changed it to 12 volt key start. Is there a later starter that I can buy that will bolt in? Ideas?? Thanks, John B. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year engine? What year clutch housing? What year flywheel? 12v electrical system? Foot-actuated starter or electric-solenoid actuated starter?
The above information will help people provide apprpriate answers.
Yes, it it is very likely that NAPA and many other vndors will have a bolt-in starter.
| | | | | Joined: Oct 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 49 | Engine according to Date code and serial # is 1954, 235, 3100 truck, built March 30th at Flint Mich. At this time I have to assume that the Clutch, Bellhousing and Flywheel are also 1954 as I know the Transmission and torque tube driveline is. The starter that broke was a 6 volt as the solenoid on the starter was.[ The floor plunger switch was abandoned ] I got this truck as a partially assembled project[ basket case ]The truck is now wired as a 12 volt with a one wire GM alternator. While starting it the engine backfired and broke the starter drive gear and the nose of the starter. I am hoping to replace this with a genuine 12 volt gm starter that will bolt in. I can hope can't I ?? Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | John,
If the old starter was 6v, and the flywheel is the original 1954 flywheel, then a 12v starter will not have the appropriate "drive" gear.
Do you intend to use a 12v starter with a 12v solenoid? If so, you should use a flywheel from a 12v 235/261 engine.
| | | | | Joined: Oct 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 49 | | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | What Tim is asking is the flywheel 139 tooth or 168? The 139 is the standard 6V arrangement and the 168 is 12V. Both have a corresponding starter drive gear. A 6V starter will live forever even when run on 12V. What won't work as well is a 6V solenoid on 12V. The advice I was given was that although it will last, it will hit the flywheel too hard and be too hard on the flywheel teeth. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | With minor modification to the mounting the 1955-56 12 volt solenoid will fit the 1949-54 6 volt starter.
See the USA in your vintage Chevrolet! My Blog | | |
