6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
My 1954 3100 project starter housing is broken. The previous owner had changed it to 12 volt key start. Is there a later starter that I can buy that will bolt in? Ideas??
John B.
What year engine?
What year clutch housing?
What year flywheel?
12v electrical system?
Foot-actuated starter or electric-solenoid actuated starter?
The above information will help people provide apprpriate answers.
Yes, it it is very likely that NAPA and many other vndors will have a bolt-in starter.
Engine according to Date code and serial # is 1954, 235, 3100 truck, built March 30th at Flint Mich. At this time I have to assume that the Clutch, Bellhousing and Flywheel are also 1954 as I know the Transmission and torque tube driveline is. The starter that broke was a 6 volt as the solenoid on the starter was.[ The floor plunger switch was abandoned ]
I got this truck as a partially assembled project[ basket case ]The truck is now wired as a 12 volt with a one wire GM alternator. While starting it the engine backfired and broke the starter drive gear and the nose of the starter. I am hoping to replace this with a genuine 12 volt gm starter that will bolt in.
I can hope can't I ??
John,
If the old starter was 6v, and the flywheel is the original 1954 flywheel, then a 12v starter will not have the appropriate "drive" gear.
Do you intend to use a 12v starter with a 12v solenoid? If so, you should use a flywheel from a 12v 235/261 engine.
JB
What Tim is asking is the flywheel 139 tooth or 168? The 139 is the standard 6V arrangement and the 168 is 12V. Both have a corresponding starter drive gear. A 6V starter will live forever even when run on 12V. What won't work as well is a 6V solenoid on 12V. The advice I was given was that although it will last, it will hit the flywheel too hard and be too hard on the flywheel teeth.
With minor modification to the mounting the 1955-56 12 volt solenoid will fit the 1949-54 6 volt starter.
My Blog
