1 members (Gray_Ghost), 79 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#908206 01/02/2013 5:07 PM
is there way i can make my tranny ( 2 speed P/G shift a tad bit sooner still seems just too late
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #908213 01/02/2013 5:40 PM
Adjust the lever that goes from the carburetor to the transmission. I would shorten it a little bit and try it.
lilrobo #908214 01/02/2013 5:41 PM
ok shorten ?? maybe 1/8 or 1/4 ?
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #908217 01/02/2013 6:03 PM
Give it a try, you can alway put it back and go the other way if you have to.
lilrobo #908234 01/02/2013 7:27 PM
I can't remember. Does a glide have a vacuum modulator on it? That would affect when it shifts. I thought the lever going to the carburetor was for the kickdown adjustment. Such as doing 30 mph in high gear, flooring the gas pedal, and it would kick the trans into low gear.
1939 Chevrolet Stake Truck
lilrobo #908236 01/02/2013 7:44 PM
Thats what i thought also it does have a mod valve, i always thought that the mod valve had a small allen screw that you turn, , when i replaced the old one i took it apart to see and nothing was in there, , so i am back to were i was sorry , but theres git to a way to adjust it, , its just a hair too long , i afraid that if i go to sell it, it might hurt, , but i its for me too , now i fether the gas and it changes
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #908439 01/03/2013 6:50 PM
Do they make a adjustable mod valve?
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #908556 01/04/2013 9:21 AM
Is this a cast iron glide or aluminum?
lilrobo #908566 01/04/2013 9:58 AM
If it's original to the car it will be cast iron.
My 46 GMC on Photobucket
lilrobo #908568 01/04/2013 10:00 AM
I still think that you need to adjust the rod between the carb and the transmission. Adjustable modulators are available for some transmissions but they didn't come from the factory with them.
lilrobo #908710 01/04/2013 7:48 PM
cast iron tranny ,,, so you think extending the rod a little will do it or shorten it
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #908717 01/04/2013 8:00 PM
if the throttle linkage pushes on the rod as the throttle is opened, then shorten the rod and it should shift sooner.
If the throttle linkage pulls on the rod as the throttle is opened then the rod will need to be made a bit longer.
I don't remember if the throttle linkage pushes or pulls on the rod to the transmission.
Also, make sure the vacuum supply to the modulator valve is ample. Make sure there aren't any holes in the line to the modulator, and make sure there is vacuum at the modulator.
If you pull the vacuum hose off the modulator and transmission fluid comes out, even a small amount, replace the modulator.
lilrobo #908728 01/04/2013 8:19 PM
Thanks roy, i did replace the mod valve once, i did have fluid in the line, i will get on the adjustment in the morn
Thank
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #908900 01/05/2013 4:06 PM
hey roy
i checked and there is no adjustment on that rod ,, the only adjustment is were it connects to tranny ,, i could take it loose and adjust it there ,, just a nut,, i'll do some more research
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #908923 01/05/2013 5:32 PM
That is correct, adjust it at the transmission. Go a turn at a time, and try it. It takes some time but you'll get it.
lilrobo #908940 01/05/2013 6:26 PM
ok thanks so i am on the right track
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
