1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 6 New Guy | | New Guy Joined: Jul 2010 Posts: 6 | Has anyone here used the Carter Weber carbs from Langdons on a 235 Chevy with the Fenton dual intake? | | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | Yes, I bought his CW setup along with his HEI. Was some of the best money I ever spent. That was 3 years 15K miles ago. | | | | | Joined: Jul 2010 Posts: 6 New Guy | | New Guy Joined: Jul 2010 Posts: 6 | | | | | | Joined: Jan 2001 Posts: 1,423 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,423 | Check my signature below. Love them and this is on a daily driver only vehicle.
Regards,
Cosmo
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: May 2006 Posts: 12 New Guy | | New Guy Joined: May 2006 Posts: 12 | I purchased the Carter Weber carbs from Tom Langdon and also the HEI. Running the stock 3:90 rear with 3 speed + Borg Warner overdrive in my 55 1st series. Runs great and very resposive. I couldn't be happier. I also have Fenton cast iron headers with very small glass packs. I like the exhaust sound until I go above 2500 RPM which isn't too often. I see that Cosmo uses an X pipe. I am thinking of installing one. Would that mellow me out a little in the 2500+ RPM?
Thanks Grant | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I had the same problem, I ended up putting a set of magnaflows after the rearend, as well as the cherry bombs, it is just about right now. I would contemplate removing the forward ones and just using the mufflers that I had to install behind the rear end. But I'm not sure, maybe someone else has some experience that way. (moving the mufflers for different sounds) But I think the further back you put them, the mellower it will be. You don't want to give the sound waves any time to build up momentum. (at least that is how it looks to me)
