0 members (), 170 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#908005 01/01/2013 6:04 PM
anybody ever tried a cummins 6bta into a big bolt say a 6400 ,4speed manual ,,
something i,m thinking of doing .
live or die do it with spanner in hand
Grigg Mullens may have some good input to this topic. Hopefully he will see it and comment, even though he is doing a Detroit 4-53.
I know about 3 years ago a guy was posting on the oldgmctrucks website forum his progress in putting a 6-cylinder Cummins from a Dodge in a 3800 Chevy pickup.
You can search youtube and probably find someone whose done it.
Professional Novice
Camp Commandant
Camp Commandant
You could also check on 4btswaps.com
Lots of cool conversions and grat info on the topic over there.
~ Billy
1959 GMC 860 | Pictures
At least up to 1954 the 6BT will be a very right fit, requires cab work to fit the length.
1952 Chevrolet 3800 pickup
---All pictures---
i tried to register on 4btswaps but it wouldnt recognise my email address so after the ,fitfh, attempt i gave up ..
i,m still looking at other engine options but i,m limited to whats available in the uk..
Send me a PM with your info and I'll see if I or one of the other moderators can get you registered over on 4btswaps.
Grigg
---All pictures---
I can probably offer some pointers in the 4BT and 6BT realm as well. I agree, a 6BT will be tight, however a 4BTAA with a tweaked fuel pump will put out 220hp all day long. more if you start with the 4.5 liter.
make sure you use the larger marine damper, the 4B shakes like a dog passing a peach pit at idle.
spanners #909330 01/06/2013 10:00 PM
1 Offline
Just finishing putting in a 4BT into my 1965 GMC K-10 added a 5 speed. Had almost 8" left over using the stock radiator location. Drove nice, 900lbs over the front axle. 6BT will be more, sat nicely between the frame rails. Rear quarter panels are just being painted.
Grigg sent me over to 4btswaps when I asked about putting one in here. Great site.
One guy has a 1963 crewcab with one installed. Jeff
thanks for youre input upto now,
not many 4bt engines in the uk ,and 6bt,s are getting a bit thin allthough thers still a few about ,most have gone for export to africa along wih perkins and bedford diesels
bedford 330 was going to be my first option but they are almost impossable to buy theses days ,,
