| | | Forums66 Topics128,048 Posts1,055,663 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I converted my throttle linkage from a bent rod to a threaded rod with ball stud ends, and now it is much smoother and adjustable. My local hardware store had a bin of 'miniature tie rod ends' that bolted right into the holes. I used 10-32 threaded with ball studs between the carb (Rochester B) and bell crank, and cut 1/4-28 threads on the throttle rod for a larger one. The whole setup cost me about $15 with a new spring. It is much smoother than the old setup. I used a locking wingnut to anchor the return spring on the rod.
I had issues with the old setup because of the proximity of the exhaust studs and the oil filter lines (this is a 261 with 1/2" npt lines). This solved them nicely!
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2000 Posts: 986 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 986 | Pictures we need pictures!!!!!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Here ya go. Sorry about the grime, it seems Rochester B's like to leak if you move the throttle shaft around too much while you are hooking things up. :rolleyes: [img]http://photo.starblvd.net/~guitarzan/1-1-3.jpg[/img]
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Oh, I haven't put the return spring in the stock location yet because the little tab is missing. The linkage rod is just threaded rod bent to clear the manifolds and the ends are from the hardware store, like I said before.
