3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#90775 05/08/2005 8:58 PM
Hey guys i need help with a problem. I tried to start my truck for the first time this weekend .I run wires from my battery to the switch then one wire from the ignition post to the HEI ignition then another one from the starter post to the starter.when i try to start it i think it blows the module (3 different distibuters out of running cars)I've done this dozens of times before with no problems.I put points distributer in using the same wiring and it runs great.Anybody know why it is blowing modules?
Riding in the Passing Lane
There is a metal terminal that goes under the coil to the connector. Sometimes a guy changes dist. caps & leaves the term. in the old cap.
1972 Chevy c10 Cheyenne Super
I had that trouble with a Mallory electronic ignition...burned up two modules until I found out I need to mount a resisitor between the coil and the distributor.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
I assume this is a pre-computer HEI. It should have a terminal labled TACH where the power and ground are connected.
That connector gives the same signal to a tachometer that a point type ignition would. If you put a test lamp between that terminal and a source of 12-volts the light will flash while the motor turns if the module is working.
This is the approach I've used to test these things in the past.
The GM HEI does not require an ignition resistor and will not perform correctly if one is in the circuit. You probably won't notice the problem unless the motor is turning faster than typical street driving.
I guess I assume it's an aftermarket HEI...with a non-resistor coil.
Steve G.
I put another distibuter in today ,checked and rerun all the wires ,it fired up fist turn. I must have done something wrong the first time that i hooked them up (Got in too big of a rush to drive it). Thanks
