| | | Forums66 Topics128,139 Posts1,056,758 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | Hey all
Its been too long since I took apart my windshield. now its time to put it back together.
Is there a thin rubber gasket between the glass and the inside of the frame?
I have a roll of thin rubber, about 1 inch wide in my new parts pile, I think that is what goes between the window and the frame, but I thought I would check.
sorry for the basic question
jay | | | | | Joined: Dec 2012 Posts: 27 New Guy | | New Guy Joined: Dec 2012 Posts: 27 |
just sand it a little more 47 1st series pu 4x4
| | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | I spoke with jim carter, and yes, there is a rubber seal that goes between the glass and the inner frame. they said to put some oil in the frame to slide in the glass with the rubber on the glass. I did that. It sort of falls apart easily when it gets oil on it, so be careful. jim carter sells this seal by the foot. | | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | just a note on the window sealer tape. the windshield tape is half the thickness of the side window tape. you need the extra thickness for the door windows | | |
