6 members (TUTS 59, RLB, Otto Skorzeny, 52Carl, Gray_Ghost, ShopRag), 132 guests, and 2 robots.
Topics128,130
Posts1,056,714
Members48,454
Hey all
Its been too long since I took apart my windshield. now its time to put it back together.
Is there a thin rubber gasket between the glass and the inside of the frame?
I have a roll of thin rubber, about 1 inch wide in my new parts pile, I think that is what goes between the window and the frame, but I thought I would check.
sorry for the basic question
jay
i too need to ask this?
just sand it a little more
47 1st series pu 4x4
I spoke with jim carter, and yes, there is a rubber seal that goes between the glass and the inner frame.
they said to put some oil in the frame to slide in the glass with the rubber on the glass. I did that. It sort of falls apart easily when it gets oil on it, so be careful. jim carter sells this seal by the foot.
just a note on the window sealer tape.
the windshield tape is half the thickness of the side window tape.
you need the extra thickness for the door windows
