3 members (2-Ton, Mike B, 1 invisible), 69 guests, and 2 robots.
Topics128,030
Posts1,055,419
Members48,422
#90772 05/04/2003 2:23 AM
Junior Member
Junior Member
I recently picked up a 53 1/2 ton with a 235. The casting number shows a 54-57 block. The generator pulley didn't line up with the harmonic balancer and the water pump so I put a spacer in line to even things up. I just burnt out the generator and need to know how to replace it with the right one. Do I need the long or short shaft one. I've converted to a 12 volt system. Any ideas?
#90773 05/07/2003 12:28 AM
I was just putting the generator and hardware back on my motor. It is a Canadian 216 and it looks the same as a 235. When I installed the generator bracket on the block, I thought that it was the same at both ends. What I discovered was that the generator pulley didn't line up by a small amount. I turned the bracket around and the generator line up perfectly.
1951 1 Ton Completed
#90774 05/07/2003 7:32 PM
You can also slot out the bolt holes if that doesn't work. You can fit an alternator on there by flipping both the bottom and top brackets over and bending the top one slightly.
Paint & Body Shop moderator
