0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
So when I get tired or frustrated with doing mechanical repairs/upgrades on our 55.2 3600, I walk to the other side of the shop and dig back into the bodywork on our 51 310 currently under the knife.
I have the drivers floor and rocker panel off and was lining up the new rocker panel. My question is can the forward and back placement vary a bit without affecting the front end body panels lining up? And yes, I do realize that the attaching bracket that holds the inner fender to the firewall has a large hole and two bolt holes that needs to line up with the ones in the front of the rocker panel. BUT..... WHat if I dont use the original clutch setup and just bolt the bracket to the firewall wherever it needs to be to make the fenders line up? Would that work ok? I can't see where there is anything else that needs to line in a certain place on the rocker panel? Brian
1952 GMC model 473 dump truck
1951 Chevy 1500 stepside
the rocker needs to go in so the fender gap to rocker is correct
you need the door installed & fitting the cab perfectly first to get the proper gap from bottem of door to top of rocker & so the in & out positioning is right
allso i use weld through primer on all inside areas of the cab & rocker so when your done you dont have bare welded steel trapped inside were you might not be able to get a corrosion ressisance coating the key to long lasting repair is to seal the metal on all sides from air water etc..
just sand it a little more
47 1st series pu 4x4
