5 members (Stovebolt48, 78buckshot, Ponchogl, Shardean, dt235sd), 79 guests, and 3 robots.
Topics128,021
Posts1,055,349
Members48,420
Page 2 of 2 1 2
lilrobo #906952 12/28/2012 11:29 PM
lilrobo,they do make a special tool for doing the procedure,if you can't do it with a screwdriver and wrench.Type this into ebay search and you will see it. Engine Rocker Arm Adjustment Tool Zim Mfg co
Tim
1951 3100 Chevrolet
lilrobo #907001 12/29/2012 10:04 AM
Get one adjusted while engine is running, then if you want, shut it off and adjust the rest the same amount. Just be sure each one is off the lobe of the cam.
The ticking in the morning could be one slightly loose still, you could give all of them a 1/4 turn more, or next cold morning, pull the cover and look for the loose one only and tighten it down. One lifter may be worn or machined with more clearance.
Isn't this fun?
Joe
bowtietim #907005 12/29/2012 10:12 AM
Tim
Here are a few valve adjustment tools that Tim might be referring to - the ZIM and New Britain tools might be the same; and, they are more helpful than the Snap-On/Proto tools.
lilrobo #907401 12/30/2012 1:50 PM
i am real close now , its just when i do a cold start i hear them ,, i will drive it a little and re adjust them ,, 1 other thing right now when hot driving at 180 to 170 temp my oil pressure is 40+ driving ,, but at light it drops to 25 is that ok?? got me worried but as soon i get on the gas it jumps to 40 again ,, the idle is about 500 to 700 rpm just guessing no way to tell ,,
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #907402 12/30/2012 1:55 PM
It is normal for the oil pressure to drop off some at idle. It sounds like your just fine.
lilrobo #907443 12/30/2012 4:32 PM
great iam just a little gun shy after all i been through ,, this is were you dont need a gauge to look at all the time lol
thanks guys
now i can get back to my windows , replacing channels and fuzzys
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
Page 2 of 2 1 2
