7 members (Brian Moore, TUTS 59, Hotrod Lincoln, Bill Hanlon, Ponchogl, sron48, Steelonsteel),
74
Mod | | | Forums66 Topics128,045 Posts1,055,528 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 132 | I installed an Edelbrook carb. the stock linkage will work perfect,I just can't find a heim joint or fitting that matches threads on the stock rod. Not sure what the threads are. They are finer than 1/4-28. Any help would be great.
Thanks Brett | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | First measure the diameter of the rod to make sure it is a 1/4". Next go buy a brand new die that matches your Heim end threads and run it down the rod. The Heim now fits. A very sharp die is necessary so it can cut across existing threads every several rounds without getting diverted. Another approach is to use a thread gauge to find out what threads are on the rod and get a tap from a machine tool supply and run it in the Heim end. This leaves an invisible fix but a special order tap can be pricey.
Evan
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Another approach would be to take the rod to your local hardware store and find the what size it is. I know that ACE has cards with both SAE and metric thread sizes on them.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
