4 members (Joe H, Gdads51, jmoore, 3100RustyParts), 86 guests, and 3 robots.
Topics128,264
Posts1,058,350
Members48,485
#90710 06/02/2003 3:30 AM
Junior Member
Junior Member
Help I installed the new harness from chevy duty everything went great. then the time came to hook up the turnsignals how do I put the break lights and turnsignals on the same light.
I've never been lost just confused for a month or two. 1950 & 1952 chev. 1998 Chev 4x4.
#90711 06/02/2003 3:47 AM
The wire from the brake light switch should lead into the signalstat, though I couldn't tell you which lead to connect it to without looking at it. The signal switch will turn off the brake light to the side you are signaling with.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
#90712 06/02/2003 4:35 AM
I have signal stat directional wiring schematics on my website which might help you get it all done up correctly.
Signal Stat Directionals - Wiring Diagram
#90713 06/03/2003 2:55 AM
Junior Member
Junior Member
Thank you for your replys I stop by my NAPA store and they ordered the seven wire stat that I needed. I tryed to in stall a four wire one that dose not work.
#90714 06/03/2003 4:58 PM
"MONGO"
"MONGO"
Thanks for the link, OldCarKook
I've had a Signal Stat switch for a while now that I've wanted to install. Just didn't want to tackle it without knowing what goes where.It's much smaller and shorter than the one I've been gonna use, At the moment I just have a toggle switch stuck in one of my radio knob holes. You don't have a source for a lense to go in the end of it by any chance?
Mongo
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
#90715 06/16/2003 4:28 PM
Left arm straight out = Left turn
Left arm bent at elbow with hand pointing upwards = Right turn
Left arm bent at elbow with hand pointing downwards = slow or stop.
How much simpler can it be ??
Craig
#90716 06/17/2003 3:35 AM
cmayna, most people on the highway today probably have no idea what you are talking about and would have even less idea what message you are trying to convey if they saw it. grin
#90717 06/17/2003 2:51 PM
cletis,
You are actually right. One time my wife was driving behind me and afterwards commented on my right hand signal saying that it almost looks like an obsene gesture ? I guess I need to make sure all fingers stay evenly rigid not just the inner ones. Maybe I was approaching a F*** ? wink
Craig
