7 members (52Carl, joe apple, Otto Skorzeny, 55shaker, Gray_Ghost, Hush, JW51),
147
Mod | | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 109 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 109 | Just a quick question dose it matter which line feeds the front or back I know the pressure is the same but the back of the master cylinder holds more fluid. I have heard use the bigger bowl for the front because your front pads wear quicker? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy E.C. RatRods, If your vehicle has a combination of disc and drum brakes, then yes it most definately matters where the primary (closest to the brake pedal)system is plumbed, and the secondary system is plumbed. One of the functions of the proportioning valve is to limit pressure to the drum brake system to prevent drum brake lockup. I would recommend following the plumbing schematic of a vehicle that uses the components you will be using in your brake system, hope that helps. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | As a general rule, the bigger reservoir is for disc brakes. Picture this, a caliper has a bigger fluid capacity compared to a wheel cylinder. As the pad wears, the caliper reservoir behind the piston requires more fluid to replace it than it would compared to the area inside a wheel cylinder. Look at a Corvette master cylinder. Equal bowls as the Corvette (except for some early versions ) were always disc and disc. | | | | | Joined: Nov 2012 Posts: 109 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 109 | Ok I figured as much but wanted to make sure thanks for the feed back. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | This brings up another question. On the new under the floor MC set ups, the reservoirs are the same front and rear.
Both are large capacity. At least the CCP one I got is.
Will it matter with a front disc and rear drum set up as long as the proportioning valve is working correctly?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Roy Rodgers, I believe the primary reservoir is usually plumbed to the front brakes, hope that helps. | | |
