| | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 23 | Been looking at getting another K-10, the dash has 5 holes above the radio cut out all about 1-1/4"s. No heater or ash tray cut out. Looks factory done. The rest of the dash is normal, gauge cluster ( not installed) and glove box. Wonder if anyone has seen something like this, maybe military? Thanks. Jeff | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | | | | | | Joined: Apr 2009 Posts: 108 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 108 | Sounds like aftermarket gauges to me. Has it got extra gas tanks? Maybe Oil , Temp, Amps, and for the other two: Saddle Gas Gauges or Volts, Vacuum, Incline? A Clock??... | | | | | Joined: Jul 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 23 | Cab is so full of stuff it is hard to get in there, I did feel on the inside just now and looks like someone did patch it in and did a nice job. Took a picture and will try to post it. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | you will have to post to photobucket or whatever and then link it to here ron | | | | | Joined: Jul 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 23 | Thanks, I will give it a try. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Not a factory option. The dash was either equipped with an ash tray in the space above the radio or the A/C diffuser, on the factory-equipped A/C trucks. It sounds like the area has been infilled with a panel and new holes drilled, to accomodate the aftermarket gauges. Take a look at it from the back, to be sure.
If not, you have the only one in existence, therefore it must be priceless.
| | | | | Joined: Jul 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 23 | Hi Tony,
Posted this before I spoke to you, turns out the owner did cut out and patch in a panel with holes for gauges. Then tore the truck apart and that was 20 years ago. Came stock with a 283 and 4 speed as you talked about. He has the pink and lots of NOS parts, wants to put a LT1 motor in it and change out the axles and basically ruin the thing.......Needless to say I am trying to buy it, though right now it is a rusting pile of........ Thanks for your help and input on my GMC! Jeff | | |
