6 members (Hotrod Lincoln, UtahYork, Cletus1950, MickeyP, Gdads51, Wayne67vert), 72 guests, and 3 robots.
Topics128,179
Posts1,057,068
Members48,460
Hello I'm looking for the metal trim that goes around the door glass... I have seen were you can get the whole thing with the glass but I don't need the glass mine is good... Anyone know where I can get this ?
Post an ad in the parts wanted section of the forum
Should have pretty good luck there
Ok thanks
Jim carter has the window weather stripping you need.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
