| | | Forums66 Topics128,052 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90663 03/06/2002 1:40 AM | Joined: Nov 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 46 | I picked up a magnetic pickup style tach - such a deal!!! Now my problem is that it's calibrated for 4 or 8 cylinders and I have a V6 305. There is a calibration sticker on it, and using the ratios listed, I think it will display correctly if I get the pickup end of things correct. On the sticker it says for 8 cylinders and mag pickup "180T", which I interepted as putting two pickups 180 degrees apart? Under 4 cylinders it says "90T", so I'm thinking that for a 6 cylinder could I put 3 pickups 120 degrees apart??? Can I get the magnetic pickup at NAPA??? Should I just chuck this sucker in the dumpster and start over?? Thanks in advance Scott :confused: | | |
#90664 03/07/2002 4:48 AM | Joined: Sep 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 85 | Showing my ignorance here, but I never heard of a magnetic tach pick up. the only tachs I have ever seen were mechanical (early vettes) or electronic (negative side of ignition coil).
Just where are you supposed to place the sensors? By Flywheel? Vib Damper? | | |
#90665 03/07/2002 6:10 AM | Joined: Nov 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 46 | Curly....I'm with you. At any rate, I think the "mag pickup" type would work with a pickup (coil) and several magnets placed at increments that would corellate to degrees of crankshaft rotation. I'm gunna call the company that made the sucker and find out. | | |
