4 members (Gray_Ghost, Jon G, Otto Skorzeny, 1 invisible), 96 guests, and 8 robots.
Topics128,181
Posts1,057,189
Members48,465
It's the metal piece that runs "under" the hood between the hinge and the top of the radiator. You can see the ridge of it in the gap between the two hood pieces. Mine's dented. I've looked on all the "regular" places and no luck. Any ideas would be appreciated. Thanks!
It is called the front hood support. They are not reproduced, however they show up on ebay often in the 20-30 dollar range.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
Are you working on a Chevy or GMC? They're different, you need to be careful to get the right one, though the GMC ones are quite hard to find I did get mine on Ebay. The GMC piece is pronounced above the hood, giving it a big-nosed appearance.
My 46 GMC on Photobucket
