9 members (Gdads51, Shaffer's1950, 78buckshot, Phak1, Leo, dt235sd, Jon G, mick53, 4tttt8),
87
Mod | | | Forums66 Topics128,181 Posts1,057,180 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | It's the metal piece that runs "under" the hood between the hinge and the top of the radiator. You can see the ridge of it in the gap between the two hood pieces. Mine's dented. I've looked on all the "regular" places and no luck. Any ideas would be appreciated. Thanks! | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | It is called the front hood support. They are not reproduced, however they show up on ebay often in the 20-30 dollar range.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Are you working on a Chevy or GMC? They're different, you need to be careful to get the right one, though the GMC ones are quite hard to find I did get mine on Ebay. The GMC piece is pronounced above the hood, giving it a big-nosed appearance. | | |
