1 members (baldeagle), 33 guests, and 6 robots.
Topics128,014
Posts1,055,327
Members48,419
#90656 06/27/2003 10:05 AM
Hello -
I recently put on a new starter switch on my starter on my '51 Chevy 1/2 ton. All is great with it. I hardly ever drive my truck after dark, but this evening I was checking all the bulbs etc, and discovered that my headlights and front parking lights are not coming on. I put in brand new bulbs, and still no headlights or parking lights. All my other lights work (dash guages, tail lights, brake lights, dome light). The hot line running from the new starter switch into the fire wall is carrying about 6.25 volts (I'm still a 6 volt system). I'm assuming this wire then runs to the light switch on the dash. I know that there is a breaker in the switch, but, it is my understanding that if the breaker is out, NO lights will work at all. I tested the bolt posts out on the wheel well where the wires run to the headlights and parking lights, and there is no power there. So, the power is lost somewhere between the time the wire runs into the firewall, and basically the headlamps.
Any ideas?? Maybe just a bad light switch??
THANKS!!
Bernard Laiben
1951 3100 Chevy Deluxe Pick-up (original with 73,000 miles on a "straight Six" 216)
#90657 06/27/2003 2:27 PM
If I remeber correctly the main power goes thru the amp meter and then to the headlight switch. Since you have dash lights I am speculating that the head light part of your headligh switch is bad. This could be checked by moving the wire to a different lug and seeing if the headlights work.
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#90658 06/27/2003 3:41 PM
Have you checked to see if you have power going down to the dimmer switch? If the dimmer is out...you won't have light even if the headlight switch is good.
Joe
Joe
#90659 06/28/2003 4:31 AM
Junior Member
Junior Member
Check the circuit for resistances and propers grounds.. basics first
#90660 06/28/2003 5:52 AM
I got it fixed! It WAS the dimmer switch Chevy1 !
Thanks for the great advice. I also went ahead and took out the switch and cleaned it real good while I was working on that particular project.
Bernard Laiben
