7 members (3B, Phak1, 1955 1 Series, Gib70, Joe H, KEVINSKI, 1 invisible),
133
Mod | | | Forums66 Topics128,092 Posts1,056,451 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 5 New Guy | | New Guy Joined: Sep 2012 Posts: 5 | I am looking to purchase a 1963 Chevy C60 2-speed tandem axle dump truck (gas 350 engine).
My question for you all is, does anybody have any information on the clutch linkage system? The clutch is there intact, but there is no linkage between the clutch and the transmission whatsoever, and I have had no luck looking elsewhere online.
Thank you in advance, Dave | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy davidcope, welcome, I believe your truck came with a hydraulically activated clutch. Your master cylinder on the firewall should have two outlet tubes, one for the brakes and one for the clutch. There should be a slave cylinder mounted on the right side of the bellhousing, with a short connector bar between the slave and the clutch fork, hope that helps. | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | 3B is correct, hydraulic clutch all C & K models from '60 -'63, cab over truck use them well past that. If you look close on the master cylinder cast in above the ports for the line should be 'clutch' & 'brake'. Stock v8 would have been a 283. Good thing it's not a year older, you'd be looking for the front springs!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | Not sure about the C/K30 and higher, but for C/K10 & 20, the hydraulic clutch was used last in the 1962 model.
The thing to look for is a dual master cylinder (Brake/Clutch) and a slave cylinder (or mounts for one) on the passenger side of the bellhousing.
The dual master cylinder is configured side by side, not stacked like a later model dual.
| | | | | Joined: Sep 2012 Posts: 5 New Guy | | New Guy Joined: Sep 2012 Posts: 5 | So should I be looking for a short connector bar between the slave cylinder and the clutch pedal rather than a cable of some sort? I've tried almost all of the parts stores in town, and nobody carries, or even has a diagram for, what I'm needing. Any help is appreciated, thanks again guys.
Dave | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | there should be a pushrod from the slave to the throw out arm ron | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy davidcope, it has been a long time since you first inquired about your clutch linkage. Does your truck have a dual chamber master/clutch cylinder, there should be two hydraulic lines attached to it if it does?
| | | | | Joined: Sep 2012 Posts: 5 New Guy | | New Guy Joined: Sep 2012 Posts: 5 | Hy davidcope, it has been a long time since you first inquired about your clutch linkage. Does your truck have a dual chamber master/clutch cylinder, there should be two hydraulic lines attached to it if it does? It looks to me that it is a dual chamber, here's a picture of the cylinder on the firewall: http://imgur.com/DrjoU | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy davidcope, thanks for the picture, yes that is a brake/clutch master cylinder, so you definately have a hydraulic clutch. There should be a short connector bar between the slave cylinder and the clutch fork coming out of the bellhousing. This bar is where the clutch adjustment is accomplished, I'll see if I can find a picture. I think the connector bar could be fabricated with very little work. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Here is a link to my scan of the clutch slave cylinder: http://i120.photobucket.com/albums/o178/pintos4me/clutchslave0001.jpgGroup number 0.775 is the adjustment rod, 0.793 is the special vertical nut with the 3/8 n.f. thread, that would be the tricky part to make, if you posted in the parts wanted forum and referenced this picture maybe someone will have one, hope that helps. | | | | | Joined: Sep 2012 Posts: 5 New Guy | | New Guy Joined: Sep 2012 Posts: 5 | Wow, thanks so much for this information! As I'm not very familiar with much of this yet, one more question... Here is the only picture I have of the clutch inside the cab: http://imgur.com/vMNAR Is the linkage in your image all located above what's in my picture? I didn't look close enough the few times I've had access to the truck, and obviously I don't know enough about the system as it is. All I know is the clutch is either in the normal "up" position, or it snaps right to the firewall...there is no in-between (you can see the dent at the very bottom of this picture). Is this due to the clutch being out of adjustment? I apologize for my ignorance, my knowledge is limited to passenger vehicles! Thank you so much for all of your help so far, Dave | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | it will be mounted on the side of the bell housing and may be on the passenger side ron | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy davidcope, as padresag said the linkage is mounted on the right (passenger) side of the bellhousing. Now that you have a picture you could copy it and take that to your local wreckers and see if they have any or all of it. Don't be surprised if you have to rebuild/replace the master and slave cylinder, hope that helps. | | | | | Joined: Jul 2010 Posts: 4 New Guy | | New Guy Joined: Jul 2010 Posts: 4 | i looks exactly the same as my 62 C30 clutch master slave setup the slave blew out i tried to rebuild but i ended up having to replace it with a newer model slave with some new bolts and some spaces seems to be working | | |
