2 members (Shardean, Otto Skorzeny), 103 guests, and 1 robot.
Topics128,024
Posts1,055,392
Members48,422
#90609 05/18/2003 1:11 PM
hey all on my 52 when I go to start the ol'girl I have to move the starter pedal up & down with my foot in order for it to engage is there an adjustment somewhere that I can eliminate this problem thanks
#90610 05/18/2003 2:32 PM
Sounds like the switch on top of the starter is starting to get a littl erough on the internal contacts.(or the linkage bolts for the starter pedal are loose)
#90611 05/18/2003 4:28 PM
well it's rainin here like a cow... so not much I can do need to do some spring tune up on was goin to the garage for beatin & bangin guess I'll wait till sun shines again b4 I can check thanks
#90612 05/18/2003 11:35 PM
freydaddy,
Is there a return spring on the linkage above the starter (to return the foot pedal to the "up/non-engaged" position)?
I'll post a picture if you have no spring.
Mechainiac is mostly likely right - you need a new Starter Switch (solenoid).
http://www.americanclassic.com/asp/...&iyear=1954&ytype=to&exyear=
Tim
#90613 05/19/2003 4:42 AM
Big Bolt Shop Curmudgeon
We're just guessin' here, because we're going on your description, but most likely, the fellers have it pretty much right. It is likely the starting contactor switch. Don't be calling it a solenoid--that is a very specific kind of electrically driven contactor switch.
The starting contactor switch is easy to replace and you will know immediately if that was the solution. If you replace the switch and the ol' girl still won't crank when you mash the starter pedal, then you got some wires in the starter motor that are not right--commutator, brushes, field wiring--work for a professional.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
#90614 05/19/2003 6:49 AM
The switch is still available at Napa and costs around $12.00.
Do you have a helper who can push on the pedal and you can watch to see how well the contact lever enguages the button on the switch?
#90615 05/19/2003 3:00 PM
ok guys the rain has quit for awhile so today maybe the day I can take her to the garage my helper is too small to reach the pedal so maybe mawmaw can come help for a few minutes.so of you know how she feels about my truck but I will keep ya posted thanks
#90616 05/19/2003 8:09 PM
ok got under the hood talked mawmaw into pushin on the pedalthe lever press'sdown great makes good contact nadda looks like the switch is histo is there any way I can bypass and get the thing started?thanks
#90617 05/19/2003 10:11 PM
No, but you can push it.
Paint & Body Shop moderator
#90618 05/19/2003 10:44 PM
thanks for all the replies and will push it my wife says to push over mountain
#90619 05/20/2003 7:25 PM
hey good news! I removed the switch on the starter ,looked under the switch found a small strip of copper under the button it was gone where it makes contact w/the starter and battery wire.I took a piece of copper the size of a (penny) cut & snip and....IT'S ALIVE!!!!
#90620 05/20/2003 10:32 PM
That will get you by for a while until it moves a little bit and grounds out letting the smoke out of the wiring and battery cables eek
Is the copper strip piece that is missing the part on the starter or on the switch?
#90621 05/21/2003 1:24 AM
on the switch and only temporary
