| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | there is a 1/4" plug right beside the lower oil line on my 62 261. what is this for. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tim, You might want to post a photo of that plug/hole, to make sure we know what is being referred to. If the plug almost fills the oil line opening, a full-flow filter has never been installed. That plug is supposed to be pushed aside when the full flow filter is used. After the plug has been moved aside, it is imperative that a full-flow filter be used, or a jumper line should be placed between the two oil filter ports on the block. I do not know if a bypass filter can safely/effectively be used when the plug is visible (has not yet been moved aside). Wait to hear from others for a confirmation or correction. | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | looking at the link you posted the left oil line has a plug right beside it about 3/8 of an inch away to the left. not the pin that is pushed in or out. looks like s 1/4" pipe plug I never really noticed it when i painted the engine but it's there. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tim, I think I have that same plug and pay it no heed. added later: I was wrong, Tim, I do not see that plug in this photo? I think the 1959 261 in my old truck had that plug, however. Maybe someone who knows about that plug will reply.
| | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | your right, your block doesn't have it. wonder what it is. maybe a place for a oil pressure line.
| | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | 261 block plug [url=261 block plughttp://s1062.beta.photobucket.com/][/url] | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | His links are not working for me. Here is a pic he emailed me. 261 plug link Again, he wants to know what is suppose to go in the plugged area. I think it is for the oil pressure gauge. Can someone with a 1958-63 261 confirm this.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | wow. finally with the help of my wife i did it. now, does anyone know what this is. | | | | | Joined: May 2004 Posts: 45 New Guy | | New Guy Joined: May 2004 Posts: 45 | I just looked at my 1960 261 block on the engine stand and it has that same boss area but it is not drilled. I can see though that it connects to the same oil gallery as the adjacent hole for the full flow filter. I would presume it was for an oil pressure gauge line.
Ed Fallon In seemlingily endless process of restoring a stock 1953 chev 3100 pickup.
| | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | after spinning the oil pump with a drill there was no oil coming from this hole. I can push a wire down it till it hits the oil pan but now oil comes out. think i'll plug it back and after i start the engine i'll loosen the plug to see if oil seeps out. | | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | If I.m not mistaken, the 1/4" tapped hole is where filtered oil from the partial oil filter system dumps back into the crankcase. | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | That makes a little more since. I never thought of that. Thanks. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | His is a 1962 block with a full pressure oil system, not partial.
Drew
