5 members (WICruiser, Gdads51, 55shaker, Ponchogl, DadsFirstPickup), 121 guests, and 1 robot.
Topics128,054
Posts1,055,782
#90579 03/13/2005 1:03 AM
Junior Member
Junior Member
Working on my 59/3600 trying to get the dome light to work(never worked since I bought it last year) and discovered a brown wire with a white stripe hanging down when I removed the switch from the dash. I connected the plug to an open pole on the switch and the light worked but stayed on constantly. Where would this wire go to make it work like it should?????
#90580 03/13/2005 3:15 AM
On my 57 I believe the dome lite has constant voltage and the switch makes and breaks the ground connection. If I remember right the terminal is at the front of the switch - knob end. Someone please correct me if I'm wrong, its been awhile since I worked on it.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#90581 03/13/2005 4:17 AM
the wire you have hanging is the hot wire, and the only one to the light - ground for the light is the light mounting to the cab
if you can see under there grin the terminals have code letters that indicate what they are - there's no brown/white runner shown in the wiring diag
the interior lite is controlled by the rotation of the knob - one way dims dash lites, other way [click past full brightness of dash lites] gives the interior lite - find the terminal that has the dash lites on it and the other will be right close - may be it was disconnected cuz the switch messed up and the PO couldn't turn it off!
#90582 03/13/2005 5:26 PM
Riding in the Passing Lane
Log on to www.chevy.tocmp.com for a wireing diagram. smile
1972 Chevy c10 Cheyenne Super
#90583 03/13/2005 7:40 PM
oh yeah - but leave the www out - the diagrams are in pdf - here's the pic of the switch: http://chevy.tocmp.com/1955truck2shop/55ctsm1203.htm
