| | | Forums66 Topics128,185 Posts1,057,294 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 36 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 36 | Hi, I have title to a 55 second series Chevrolet truck. I have heard a couple guys talk about my truck and they said it was a GMC and not a Chevrolet. I overheard them say that the cab was a GMC. Can someone tell me the difference between a Chevrolet and a GMC cab. My cab is a "big window" cab. Thanks again for your help in advance. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | The GMC cab for second series has round gauges where the Chevy has a single triangular shaped cluster above the steering column. That's one obvious difference I can think of. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The main difference in the cab is the dashboard. The Chevrolet has a V shaped geage cluster , with the Ammeter, Gas, Temp, and Oil gauges across the top of the V. The GMC has a more or less rectangular gauge cluster, with all of the gauges being circular and set in a die cast panel. There are some other differences in the shape of the dash due to the differences in the guage clusters, plus the GMC would have a provision for a radiator core support brace that is not present on the Chevrolet (exept Suburban/Panels) on the firewall.
Bill Burmeister | | |
