1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#905208 12/21/2012 10:43 AM
have the windlace installed...works great. Headlights will be better with the new bulbs, once I order them from the supplier mentioned earlier. Had a problem with headlights not working,...again. Solved with sourcing to a double fused light control switch.
About the hubcaps.. I have an S-10 rear-end installed on my '37 truck. Works great. Used the 4-wheel drive option to gain a little better gas mileage. It is a 5 lug wheel, the old, '37 had a 6-lug wheel. The front wheels on the truck are still '37, 6-lug. The original hubcaps have clips on the wheels to retain the hubcaps. The new 5-lug wheels have nubs stamped into them to retain the caps. I cannot find duplicates to the original which will attach via the nubs instead of the clips. I have studied the original hubcaps and am wondering is anyone has tried to modify them to fit the nub type of wheel? It looks like a rolling of the inside lip would do the trick. I need to go from the 7 3/4" or so now on the original caps to the 7 5/8" or so of the new wheels. I can buy all new caps, but I really like the old ones. They have a black swoop on them vs the new ones with a blue swoop. I also imagine the old ones are a little heavier metal.
david miller #905429 12/22/2012 10:16 AM
Wheelsmith will modify them so that you don't have to worry about losing a cap at speed. That's the route I'll be going.
My 46 GMC on Photobucket
46gmcpu #905563 12/22/2012 10:05 PM
thank you for the reply. I will be contacting Wheelsmith.
46gmcpu #910212 01/09/2013 8:20 PM
I have sent several e-mails to Wheelsmith, called the 800 number. NO response either source. Have you talked to them?
david miller #910319 01/10/2013 10:28 AM
No I haven't contacted them yet. I just got my hubcaps, and was planning on calling them within the next week. I'll let you know if I can get through.
